EASA - The Electro•Mechanical Authority
NOTICE: The EASA website will be down for maintenance beginning at 6:00 am CST, Monday, February 16, and will remain offline for approximately 2 hours.
RESERVE YOUR ROOM FOR THE 2026 CONVENTION  RESERVE YOUR ROOM
Explore Careers in the Electromechanical Industry
The electromechanical repair industry offers exciting and varied job opportunities for employees that want to be part of an industry that's essential to everyday life. Explore the many technical and non-technical positions in typical service centers!
EXPLORE THE CAREERS FIND SERVICE CENTERS NEAR YOU
If you're a member, EASA has a video and other resources to help promote your business to potential employees.
New in 2025: 72 Enhancements to EASA's AR100 Standard
ANSI/EASA AR100-2025EASA’s “Recommended Practice for the Repair of Rotating Electrical Apparatus” is designated ANSI/EASA AR100 and was first approved as an American National standard in 1998. Since then, it has been revised and approved five more times, in 2001, 2006, 2010, 2015, 2020 and now in 2025.
ANSI/EASA AR100 is a must-have guide to the repair of rotating electrical machines. Its purpose is to establish recommended practices in each step of the rotating electrical apparatus rewinding and rebuilding processes.
READ MORE & DOWNLOAD BUY PRINTED COPIES
New 11-Part Leadership Lab Webinar Series Kicks Off in April 2026
EASA has engaged consulting firm OpX Solutions to conduct a series of leadership development webinars. Like the technical webinar series, the leadership webinars will be recorded and made available at easa.com to ALL interested EASA members at no cost thanks to our sponsors.
The series includes a strong ROI-based approach to support members in achieving their goals and recognizing measurable results - in business and personal goals. Each session is designed to stand alone, though they build upon topics in previous webinars.
  • Foundational Principles (Sessions 1-3): Build your leadership foundation
  • Personal Leadership (Sessions 4-5): Strengthen your self-leadership
  • Motivational Leadership (Sessions 6-11): Master leading and developing others
This is a great opportunity for up-and-coming supervisors and leaders as well as those who are experienced!
VIEW THE WEBINARS IN THE SERIES
Discover Technical, Management Training Options Now Available Online
EASA Learning CenterThe EASA Learning Center is online and ready to provide industry-specific training. You are now able to provide your employees with access to much of EASA's training without leaving your service center! Access to EASA’s Online Learning Center is sold as 12-month subscriptions and targets employees of all skill levels.
Read about the first technician to earn EASA's Electromechanical Repair Technician (ERT) Certificate.
EASA LEARNING CENTERERT CERTIFICATE PROGRAMBUY A SUBSCRIPTION TAKE A TOUR
Barry Bullard, EASA Chairman of the Board
Tech Tip: Resolving Phantom Oil Leaks in Vertical Machines
Jonathan Robinson
Technical Education Committee Member
Burford Electric Service, Inc.
Oil-lubricated vertical motors rely on a properly sized, sealed and aligned oil standpipe (Figure 1) to maintain lubrication levels without leakage. A tilted or improperly sized oil standpipe can allow oil to migrate upward along the pipe’s wall when the motor is in operation, leading to leakage, loss of lubrication and potential bearing damage. This issue can be overlooked during assembly or inspection, but a few simple checks can prevent costly problems.
  • Leak Check – Elevate the motor’s endbell on risers, and place brown butcher paper below the standpipe area. Fill the endbell with mineral spirits and let it sit overnight if time permits. Check the paper for oil drips. If necessary, reseal the standpipe.
  • Visual Inspection – Check for threading on the inside diameter (ID) of the motor’s bearing carrier (Figure 2) or the outside diameter (OD) of the standpipe that can cause oil to climb the standpipe when the machine is in operation.
  • Confirm standpipe seating – The standpipe should be fully and evenly seated in the motor’s endbell. Uneven seating can create a tilt and lead to leaks under operating conditions.
  • Checking for standpipe tilt – If a coordinate measuring machine (CMM) is not available, an ID micrometer can be used to check for standpipe tilt. Using the ID micrometer, technicians can measure the distance between the OD of the standpipe and the inside of the motor’s endbell at four locations 90 degrees apart to verify that the oil standpipe is not tilted. A smaller measurement in any of these four coordinates indicates that the standpipe is tilted in that direction. Ideally, the measurements would be within 0.005” (0.13mm) of one another.
  • Check the inside of the bearing carrier skirt for taper - If the upper part of the clearance is larger than the bottom, it will pump oil upwards. One tip is to machine the inside of the skirt so that it is 0.020” (0.51mm) larger at the bottom than the top.
  • Standpipe clearance to shaft umbrella fit – Capillary effect can draw oil over the motor’s standpipe if the clearance between the OD of the standpipe and the ID of the shaft umbrella fit is too close. This problem is most likely to show up when the motor has had the standpipe replaced. The minimum clearance that we typically like to see between these parts is 0.030” (0.76mm) to the side.
Taking a few minutes to verify oil standpipe alignment during assembly or inspection can save hours of downtime, prevent messy oil leaks and extend bearing life. This small step is a big part of reliable vertical motor operation.
Stand pipe
Figure 1: Standpipe shown, circled.
Figure 2:  Even a light machined thread inside the bearing carrier acts as an Archimedes screw, the crudest form of a pump. It can lift oil from the sump to where the bearing carrier fits on the shaft, causing leakage.
