EASA Tech Notes - Resource Library - EASA | The...
NOTICE: EASA has disabled the online database functionality for Version 4 of the AC Motor Verification & Redesign software.
Users can either switch to the local database, or begin using EASA's Motor Winding Workbench. For help or questions, contact gvogel@easa.com.
EASA Tech Notes
  • October 2025
  • Article rating: 3.0
The latest revisions of EASA Tech Notes are now included as part of the EASA Technical Manual (as of 2012). Tech Notes will no longer be issued as separate documents once they have officially been incorporated into the EASA Technical Manual.
The list below will help you locate these latest revisions.
List updated October 2025
Number Title Page of the EASA Technical Manual
1 Hoist Troubleshooting Withdrawn
2 Function of the Interpole in DC Machines 3-29
3 Connecting the Variable-Speed Commutator Motor 2-168
4 Frog-Leg Windings for DC Machines 3-49
5 Dynamometer Testing Electric Motors 7-33
6 New International Connection Diagrams for Foreign 6- and 12-Lead Wye-Delta Motors Withdrawn
7 Suffixes to NEMA Frames 2-6
8 Understanding Motor Efficiency and Power Factor (replaced with The Impact of Voltage and Frequency Variation on Motor Life and Performance) 2-82
9 TIG-Welded Commutator Connections 3-47
10 Winding Connections for Multi-Mode Three-Phase Motors 2-158
11 Voltage Stresses in Three-Phase, AC Motors (Withdrawn and replaced with: Voltage Stress: Not as Simple as It Sounds) 2-217
12 Conversion Factors for Lap and Concentric Windings 2-181
13 Solid Round Magnet Wire Data 6-2
14 The Commutator and Its Maintenance 3-41
15 Some Aspects of Magnetic Centering Effects on Sleeve Bearing Induction Motors 10-99
16 Guidelines for Maintaining Motor Efficiency During Rebuilding 2-98
17 Stator Core Testing Withdrawn
18 Troubleshooting a DC Motor at the Job Site 3-53
19 Lubrication of Rolling Bearings in Electric Machines Withdrawn
20 Cause and Analysis of Anti-Friction Bearing  Failures in AC Induction Motors (Now titled: The Cause and Analysis of Bearing Failures in Electric Motors) 8-32
21 Thrust Anti-Friction Bearings for Vertical Motors (Now titled: Understanding and Adjusting Thrust Rolling Bearing Systems for Vertical Motors) 8-22
22 Brushholders and the Performance of Carbon Brushes 3-33
23 Testing of Squirrel Cage Rotors 7-30
24 UL 1446 Systems of Insulating Materials 6-24
25 Rewinding Inverter Duty Motors 2-114
26 Can Energy Efficient Motors Be Rewound Satisfactorily? (replaced with The Effect of Repair/Replace
on Motor Efficiency)
2-101
27
The Cause and Analysis of Bearing and Shaft Failures in Electric Motors
• Bearing Failures
• Shaft Failures
8-32
10-103
28 Assuring the Mechanical Integrity of Electric Motors 10-4
29 Application Considerations of Pulse-Width Modulated Inverters 5-40
30 Fabrication of Replacement Shafts For Electric Motors 10-121
31 The Cause and Analysis of Stator and Rotor Failures in AC Induction Machines 2-113
32 Standards for Dynamic Balancing 10-19
33 Taking Data on Form-Wound Motors and Generators 2-227
34 PWM Amplifiers 5-15
35 Rewinding Form-Wound Motors and Generators (Now titled Rewinding Form-Wound Motors and Generators up to 5kV) 2-223
36 Armature Banding With Fiberglass 10-95
37 Interspersed Windings: What Are They? 2-146
38 Repairing Sleeve Bearings 8-42
39 Procedure Writing: It Takes A Little Time, But The Results Are Worth It Withdrawn
40 An Analytical Approach to Solving Motor Vibration Problems 10-29
41 Electric Motor Shaft Analysis 10-117
42 Procedures for Checking End Play in Ball Bearing Machines 8-49
43 Making and Installing a New Motor Shaft 10-125
44 Guide for Procuring Form Wound Coils for Motors and Generators 2-231
45 Servo Drives 5-31
46 The (Potential) Pitfalls of Parallel Circuits 2-204
47 Concentric-to-Lap / Lap-to-Concentric Conversions 2-170
48 Squirrel Cage Rotor Testing (Never included in Technical Manual) See Section 7
49 Simple Troubleshooting of Amplifiers in the Field 5-24
Categories: Technical topics
Tags:
Rate this article:
3.0
PREVIOUS ITEM
