Electric motors can be repaired without reducing efficiency ... and EASA can show you how!
Proper Repair/Rewind Practices Maintain Efficiency/Reliability of Premium Efficiency/IE3 Motors  DOWNLOAD THE EXECUTIVE SUMMARY
What To Consider When Deciding to Repair NEMA Premium Motors
Is it better to repair or replace an electric motor that fails? For most plant engineers and maintenance staff, experience attests to the reliability of standard efficiency motors that have been repaired or rewound using industry best practices. Repair also can cost far less than replacement, especially if the motor has special features.
But some decision makers opt to replace failed energy efficient motors (NEMA Premium models in particular) because they’ve “heard” these motors can’t be repaired without a loss of efficiency.
So, what’s the right answer? It turns out that the decision to repair, rewind or replace a failed energy efficient motor is not always so simple and straightforward as you may have heard.
Read the complete article by Tom Bishop, P.E., EASA Senior Technical Support Specialist, at Plant Engineering.
READ THE ARTICLE
The Effect of Repair/Rewinding on Motor Efficiency
EASA/AEMT Rewind StudyPublished: December 2008
The Effect of Repair/Rewinding on Motor Efficiency: EASA/AEMT Rewind Study and Good Practice Guide illustrates that when performed properly, electric motor repair/rewind does not degrade efficiency! Nor is motor efficiency reduced through multiple repairs/rewinds.
Based on a joint study by EASA and the Association of Electrical and Mechanical Trades (AEMT) of the United Kingdom, this publication concludes that using best repair/rewind practices maintains motor efficiency.
Besides an Executive Summary, the report provides complete test data, extensive background information about test procedures and methodology, information about best practice repair/rewind procedures, resources for further reading, and an entire chapter on repair/replace considerations.
DOWNLOAD YOUR FREE COPY
ANSI/EASA AR100-2015: Recommended Practice for the Repair of Rotating Electrical Apparatus
ANSI/EASA AR100-2015 coverPublished: August 2015
ANSI/EASA AR100-2015: Recommended Practice for the Repair of Rotating Electrical Apparatus is the standard for maintaining and even improving the reliabilty and efficienty of AC electric motors.
The American National Standards Institute (ANSI) has approved revisions in EASA’s Recommended Practice for the Repair of Rotating Electrical Apparatus. Designated as ANSI/EASA AR100-2015, the document is an updated version of ANSI/EASA AR100-2010. The first Recommended Practice to receive ANSI status was ANSI/EASAAR100-1998.
ANSI requires that standards be re-approved at least every five years. The Technical Services Committee proposed over 60 changes to the Recommended Practice (ANSI/EASA AR100-2010), and the ANSI canvass (acceptance) group added over 30 more proposals. ANSI approved the revised standard and designated it as ANSI/EASA AR100-2015.
The ANSI approval process that EASA must follow requires that the document be accepted by a group that presently includes representatives of industry (end users), testing laboratories, government and other standards organizations.
ANSI recognizes only one standard on a topic; therefore, the EASA Recommended Practice is the standard for repair of rotating electrical apparatus.
Guidelines for Maintaining Motor Efficiency During Rebuilding
Published: November 2007
This article provides guidelines that service centers can follow to retain the operating efficiency of the electric motors they rewind and rebuild. It includes a list of "do's and don'ts", safe values and correct procedures based on studies of variables that can impact the efficiency of rewound electric motors (core burnout temperature, winding design, bearing type, air gap, winding resistance, etc).
This article was first published in May 1992; reviewed and revised as necessary in November 2007 by EASA's Technical Services Committee.
Can you repair energy-efficient motors? Maybe.
An EASA-authored article that appeared on the Canadian Forest Industries website — www.woodbusiness.ca
Most plant engineers and maintenance staff can attest to the reliability of standard-efficiency motors that have been repaired or rewound using industry best practices. They also know repair can cost far less than replacement, especially when the motor has special features. Despite this, some of them hesitate to have failed energy-efficient motors (NEMA Premium models, in particular) repaired because they’ve heard it degrades efficiency.
So, what’s the right answer? Is the decision to repair, rewind or replace a failed energy-efficient motor as simple and straightforward as you may have heard?
Topics in the article include:
  • What makes a motor more energy-efficient?
  • Repaired motor efficiency
  • Review the motor application
  • Catastrophic failure (present)
  • Catastrophic failure (prior)
  • Rotor condition
  • Mechanical parts condition
  • Higher-efficiency motors
READ THE FULL ARTICLE
Getting The Most From Your Electric Motors - coverThis 40-page booklet provides a great marketing tool for your service center! Use it to provide end users with information that will help them obtain the longest, most efficient and cost-effective operation from general and definite purpose electric motors.
LEARN MORE AND DOWNLOAD MÁS INFORMACIÓN Y DESCARGAR
